Got into the carb and here's what's up .... All input welcome
Old 03-06-2016 | 12:49 PM
AlbaGuBrath's Avatar
AlbaGuBrath
Default Got into the carb and here's what's up .... All input welcome
Opened up the carb last night on and found in 1996 convertible
Factory slide ( undrilled)
I assume the factory spring as it measures 5 3/4" and took approximately 13 oz of pressure for full compression ...
N72V needle which I believe is stock according to my parts and service manuals both of which are factory issued and I believe the part number is 27253-96
Mixture screw was drilled and out 3.5 turns
Slow Jet 48 Main Jet 170
The set up before I touched a thing was
Drag pipes ... Factory Air Cleaner ... And I'll assume factory cam...
The first set of plugs I pulled out weeks ago were black ... Changed the plugs to iridium and at the same time changed to the Bassani 2-1 and ordered the Ness BS stage 1 ....
I polished the slide drilled it 7/64 and bought but haven't used the #4 brass washers....
all that I've read here and elsewhere has my head spinning around what to use as a starting point as the last mod this bike will ever see is the EV27 cam and possibly very mild head work ...
Opinions suggestions and criticisms all welcome !
My opinion is that I know enough to know I don't know lol
Old 03-07-2016 | 02:39 AM
LQQK_OUT's Avatar
LQQK_OUT
Old 03-07-2016 | 06:33 AM
tomfiii's Avatar
tomfiii
Open drag pipes are worst thing to tune,need members to jump in here on pipes ,then you can start tuning carb.
Old 03-07-2016 | 06:49 AM
Owtlaw's Avatar
Owtlaw
I wouldn't have drilled the slide, but it'll probably be fine. It's a preference thing.
I think the N72V needle is a little richer in the midrange...... Think the N72S was stock, but I stand to be corrected by the Gurus around here. In any case, I think the main jet may work better at a 180 when you open up the breather with the Big Sucker. The 48 idle should be pretty close, and was probably too rich with the stock AC, which would explain the plugs being black.
Here's a needle chart I found from an unknown source....
When you get it close, a dyno tune is worthwhile for the fine adjustments.
Old 03-07-2016 | 08:31 AM
LQQK_OUT's Avatar
LQQK_OUT
He said he changed to the Bassani 2-1 in his post.
Old 03-07-2016 | 08:56 AM
AlbaGuBrath
Thanks for all the input so far fellas !
I did indeed change to the Bassani Road Rage 2-1 last weekend in fact and the butt Dyno told me there was a night and day difference ...
The Big Sucker should be here any day now ...
Old 03-07-2016 | 09:04 AM
AlbaGuBrath
thanks so much for the chart and the input ... I was on the fence about shimming the N72V as I found one obscure reference to it being one of the richest needles out there
And there are mixed opinions on the CV equivalent of the early Sporty needle ...
Great advice on the Dyno tune also ... Not looking for anything but awesome torque and reliability as the end game ( hence the cam change later to a mild cam) ... Learned a long time ago in real world street applications and my driving/riding style that the area under the curve matters most to me ...
Old 03-07-2016 | 05:55 PM
1997bagger's Avatar
1997bagger
Does your Road Rage have O2 bungs?
Not a good Dyno place in Cincy either
Old 03-07-2016 | 05:58 PM
AlbaGuBrath
Yes sir on the O2 bungs and it struck me I may have to do a little traveling to get to a Dyno ...
Old 03-07-2016 | 06:09 PM
1997bagger's Avatar
1997bagger
Get your air cleaner, jump the big jet to 180, leave the 48 and needle. Get with me on a Saturday and I'll put a Wego 3 AFR reader on it and no guessing will be needed.
Quick Reply: Got into the carb and here's what's up .... All input welcome
