Brake Squeal is Driving Me Nuts!
#51
#52
I can hear a little scratching when I spin the tire but, it could be the new rotors/pads. It doesnt drag. Im going to try to find some backing material at the parts store to go on the inboard pad that touches the piston. I really think its the cheesy oem rotors though.
#53
I ended up rebuilding both front calipers with Drag Specialties seal kits. They come with new pistons and cost around $30.00. So far, my brakes are quiet and working better than ever. Had one hell of a time bleeding the system though, even with my Mityvac, but found that tapping on the calipers helps break up the air bubbles trapped inside. Fingers crossed....
#54
I've never had any that I completely tore down an cleaned fail to work properly.
Glad you fixed it.
#55
Thats what I was doing when I found that one of the pistons was scored. When I pulled the brake lever in, that piston would push the pad out at an angle. It was wedging inside the cylinder bore. I probably could have sanded and polished the marks out of it but, it would have always been in the back of my mind. Surprisingly, the calipers were very clean inside. I couldnt find any crud built up anywhere.
#56
It's a lot more important to stop well that go fast.
Glad it worked out.
