Lifter Question
Received 4,361 Likes
"it doesn't matter" does not help anyone understand why or when "it doesn't matter", and it is not good practise. It's practical in this case, as I said ... but it's not good practise.
Unless you understand the difference, you should not say that. It's not about BGFs.
If you reread his post it is saying if you don't know how long the lifters have been run get new ones!!!!!!!!!
Using someone elses used lifters is just asking for trouble IMO!!!!!!!!!!
Hell I put new lifters in every time I go in that far as a matter of insurance and piece of mind.
A failed lifter can take a whole motor with it and I'd damn sure rather replace the lifters than rebuild the whole motor!!!!!!!!!!!
He answered that in the second half of the sentence you are partially quoting.
Best thing we can do is just not respond...or maybe we can all stop posting as BM clearly knows everything!!
I don't pretend to but I do know this...if you knew the mileage of the second hand lifters you could put them in your motor and they would work just fine until it was time to change them.....that my fellow forum members is a fact...no amount of insults from BM will change that...they'll work...true, in engineering terms it isn't "best practice" but it won't do your motor any harm whatsoever.
20,000 miles ago I put some second hand lifters into a 1987 Sporty for a guy who had one that kept deflating and he needed to get back on the road that day. The lifters had 20-something K on them (came out of a bike that had new ones fitted during a cam swap) and I gave them to him for free but charged him to fit them....they are still working, the bike runs sweet as and it's scheduled for new lifters next month.
Yeah, I do things that may not be what is in the manual or "best practice" but I know these motors well enough to keep you on the road and save you a shitload of dollars when you are on a tight budget.
If BM can't handle that or doesn't agree with it then he should keep his opinions to himself because he is making assumptions that he doesn't have sufficient knowledge to understand.
That is my last word on the subject, I'm busy, I have a 2006 Lowrider that needs another inner primary bearing to tend to, the last one was fitted by me and lasted twice as long as the one H-D fitted in the factory....clearly I have no clue what I am talking about!!
It is always "best practice" to put any machine back exactly as it was when it was taken apart.
Roller lifters don't care...as long as the OD of the lifter, and the OD of the lifter block are in spec it will work fine.
Flat tappet cams the lifter face wears to the cam lope, so if you change the position, it will have shorter life...this matters a lot on your small block chevy.
But, look ... given the nature of the original question, I made a call that turned out to be accurate, and responded to both immediate issue and the one behind it regarding basic principles or best practise. If he had them ingrained, he would not have needed to ask the question ... and may have saved himself the price of the lifters.
"It does not matter", does not do that. It doesn't help anyone.
Why on earth would anyone pick me for doing so, and argue the opposite? It's in the manual ... go argue with H-D.
Fine ... busy workshop, barking orders at clueless juniors, I can understand such a response. I'd just hope here, at our leisure, we might be a little more civil and helpful.
I was very lucky. The first guy I worked under in a workshop was a (military) naval engineer. I didn't find it "tough", I enjoyed it. I saw the logic behind it all. Came to understand what "shipshape" meant, and how improvise. It's stood me well for the rest of my life.
You can't just hop on the 'puter and order a new set when you're a 1,000 miles at sea.
Clearly in the eyes of Spanners I am.
What's the correct construction? I'm not offended by accurate correction.
I've spent years living/travelling amongst non-English native speakers, and I am conscious that my grammar is shot to pieces. Internet forums don't help.
Luckily, good practise is a Lingua Franca that doesn't require language just submission to.
