Noticed a front end rattle,could brakes be culprit?
I had to go to dr today cause I sprained my foot,(please don't ask how it happened). On the way home I noticed I had a rattle from the front. It only happens when I was moving. When I got home to inspect the bike I noticed what could be the left hand caliper is resting on the rotor. You can see it in the pic below. (sorry for fuzzy pic,not easy getting a cam in a tight spot.
I was just checking with you guys to make sure this could be causing this "rattling" on the front end and not something else.
There is a whole raft of stuff that could cause a rattle, such as the cowbells loose, fender mountings, etc. If you have floating rotors they can rattle as they get old and worn (you should see my old ones!). Your front brakes certainly need investigating, as apples points out, if only to solve why things seem to be out of alignment.
Received 4,361 Likes
Any meat on it?
