Weird electrical gremlin
Old 10-25-2015, 05:57 PM
patcham48's Avatar
patcham48
patcham48 is offline
Default Weird electrical gremlin
Hi all.
Could anyone point me in the direction of this frustrating electrical problem. Its a 1995 RK
I was out for a ride a week or so back, everything normal. Stop for a coffee and when I returned to the bike it fired up, again as normal. After riding for a couple hundred yards it pops and cuts out. I press the starter button and nothing, although I have ignition lights, the starter doesn't engage. Removed the seat, all the terminals are secure on the battery and the battery is only a couple of week old.
Try the starter again and she fires straight up. This happens every couple hundred yards.
I managed to get home, went out for a ride today and was out for about an hour. parked up at a friends house for a couple of minutes, started up just fine, but before I change in to second gear the engine cuts out and I have to go through the same process every couple hundred yards or so??????
As I say I have ignition lights but when you press the button its like its not switched on
Sorry to go on, but any ideas?
Thanks
Old 10-25-2015, 06:18 PM
WP50's Avatar
WP50
WP50 is offline
Received 1,873 Likes on 1,268 Posts
Is it FI ? Any mods? Any recent work done on it ?
W
Old 10-25-2015, 06:43 PM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is offline
Received 2,917 Likes on 1,430 Posts
Why did you replace the battery a couple weeks ago?
Old 10-25-2015, 06:49 PM
14GuineaPig's Avatar
14GuineaPig
14GuineaPig is offline
I'm not sure if you have a circuit breaker on your 95 but if you do I would check it.
Old 10-25-2015, 06:55 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 5,003 Likes on 4,194 Posts
Sounds electrical and for something 20 years old, bet it's the mechanical part of electrical. My guess is it the kill switch on the bars or the key switch. Get it running normal and wiggle them to see if it will kill motor. The starter side does not keep motor from running but killing the two mentioned parts will keep it from running and starting.
Old 10-25-2015, 07:25 PM
portlandron's Avatar
portlandron
portlandron is offline
If you have circuit breakers I ran into the same problem on my 1998 Softail. The circuit breakers are all the same. Try switching them. Solved the problem for me so I just got some new ones and replaced it.
Old 10-26-2015, 09:33 AM
falconbrother's Avatar
falconbrother
falconbrother is offline
Also check the connector that contains the white wire that comes out of the coil. Take that connector apart and clean it good, use some dielectric grease and see if that fixes it.
Old 10-26-2015, 03:32 PM
patcham48's Avatar
patcham48
W
Hi W.
No mods, completely stock. Changed the battery as the other one died
Old 10-26-2015, 03:35 PM
patcham48's Avatar
patcham48
Hi. I changed the battery as the other one died. Went to start her up one afternoon and all I got was the slow turn over and then the dreaded clicking.
This new battery is fine as the starter cranks over great
Old 10-26-2015, 03:40 PM
patcham48's Avatar
patcham48
Thanks for the advice, makes sense, I will check it out after work. Got to be something along those lines to be so intermittent.
Cheers
Quick Reply: Weird electrical gremlin
