Fuel Pump for 1996 Ultra Classic
http://www.fuelpumpfactory.com/CNT-f...nt-942-da1.htm
Has anyone tried the replacement electric fuel pump from fuel pump factory or anywhere else? The fuel pump from Harley is about $260 and fuel pump from fuel pump factory is about $50.
I would say the injectors are fine. Put some (ahhh) Sea Foam through the system if you are concerned. I did have to replace some injectors on my RN Truck, but they had somewhere around 300K miles on them and one of the 4 went bad. I don't think you will ever wear out a HD injector as long as the fuel system holds together.
If the pump is making noises, yeah, replace that, and an aftermarket one should be OK. HD don't make fuel pumps. I bought a HD fuel pump for the Sportster conversion on ebay. It was dead. I would up using one off of a Polaris Victory something or other. After I bought it and inspected it, it is just a Walpro. I could have got it at any auto parts store cheaper.
