My first break down, sorta.
Well, backed Camzilla out of the garage, went to hit that button to fire the beast up... it cranked over more than it's usual split second before firing up.. nothing! The coil went out and gave no warning.. so ,I had to push it back up my driveway back into the garage. Its got the Dyana200I ignition by the way.. looks like its time for a new coil.
Received 4,361 Likes
The difference is that you can check to see if it is the coil has failed by switching the plug wires on the coil and see if the failure moves with it.
