I hate to ask this question (electrical)
I know this isn't the sportster forum but, this is where all the good mechanics are. I (my wife) has a 1993 sporty 883/1200. The main connector (orange wire) keeps getting hot when starting and it's damaging the connector. I have fooled with it and fooled with it. Before it wouldn't even start. Now it will start and can be ridden but, no matter how much cleaning and adjusting that I do to that connector it just keeps on getting hot. That indicates, to me, that the connection is sparking, shorting, and getting really hot.
Any suggestions moving forward? Replace the connector? Jump that wire over the connector?
The heat is caused by resistance. No connector is perfect, so all will have more resistance than the wire connected to them.
How much current is flowing through that wire? Might want to put an ammeter in series and hit the starter. If I recall, a big twin starter solenoid pulls 10 amps, and I would think a sportster one should be about the same. If it is way over 10 amps, it might indicate a problem with the starter solenoid.
Otherwise, yeah, replace the connectors, or the wire or hard wire around the plug if you have to.
lots of machines do this - the one orange wire does many different electrical items - we have added an extra wire to the system from a different braker - split off one of the main draws and then the power usage is less on the one 14 g wire running stuff
just mark the wire diagram what one you pick and what colors you used, so if an issue comes up you can check it
