Props to Harley-Davidson LaCrosse, WI
I yanked my rear wheel off to change rear tire. Instead of changing it myself I opted to see how much to mount and balance from local shop. Called HD dealer 1st, and to my surprise only $38. I had rear tire already, not purchased from them. Dropped it off and they had it done inside the hour. I ran a couple errands and it was done, $38 out the door. Pretty cool, its on and done. Dunlop American Elite is brand I went with. Only because there's plenty of life left on the front Dunlop tire, Metzler 888's will be the next round of tires. Only had enough time to head down hwy and back a few miles, but so far so good. All total $190, $152 for tire, $38 mount and balance, and my labor. Worn tire had a weird wear pattern too. More wore on left side of tire than right, considerably. It'd been awfully squirrely lately, blamed it on an almost bald tire. It had to be misaligned. No cotter pin in axel nut either. PO had that tire put on before I bought it. So glad I went in and did this myself, now I know whats what.
when I put wheel back on I did yes. What I found was the adjuster stud on the right side was spinning. So basically getting that side even to the belt side needed special attention. Both sides are even now. I didn't think to measure them before removing the wheel. Bike tracks true, I can ride no handed. Lol
I have flirted with alignment issues for a long time. Measure to this point or measure to that point. It always seemed to want to pull a little to the right. So I would then go to the road test and make an adjustment to the right side adjuster either front or back and would get it close but never truly on. what I've finally done to get it real close was when I had my primary totally removed I used a string to line up both front and rear pulley's and that seemed to work but it still pulled a little to the right but not all the time. So the only thing I can figure is that the crown of the road is causing the bike to veer to the right and not the actual wheel alignment.
