Primary leak?
Old 09-17-2015, 06:42 PM
br549A1's Avatar
br549A1
br549A1 is offline
Default Primary leak?
How does one loosen the primary to engine bolts? I can't get a socket or open end on either
  #42
Old 09-17-2015, 06:50 PM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,361 Likes on 1,953 Posts
You did bend down the lock tab right?
  #43
Old 09-17-2015, 06:58 PM
br549A1's Avatar
br549A1
br549A1 is offline
The ones on the top going down attaching the transmission to the engine. No lock tab. There's two
  #44
Old 09-17-2015, 08:21 PM
texashillcountry
Dirt don't hurt
Have you tried a swivel joint on the socket?
  #45
Old 09-18-2015, 05:00 AM
br549A1's Avatar
br549A1
br549A1 is offline
No. I didn't think I could get enough torque behind it. A wobble won't fit I'll try the swivel. The one on the right side is even harder to reach
  #46
Old 09-19-2015, 11:16 PM
Spanners39's Avatar
Spanners39
Spanners39 is offline
Would there be any benefit to loosening the two trans to engine mounts now then retorquing? To relieve any stress that may be on the ring. . I have a feeling this wasn't my last time with the inner off if that lip starts leaking.
1: Yes, it's a good idea.
2: Then take it apart and do it properly this time would be my advice...
  #47
Old 09-20-2015, 06:10 AM
br549A1's Avatar
br549A1
br549A1 is offline
Loosened and retightened the trans to engine bolts. Will be watching for leaks no. If that ring is leaking I guess I'll see it fairly quickly. I didn't see signs of it leaking when I pulled it apart. Only the jackshaft and the ipb seal. I was more concerned with the stress on it or reason for the crack.
  #48
Old 09-23-2015, 05:03 PM
br549A1's Avatar
br549A1
br549A1 is offline
My luck, wouldn't wish it on anyone. 30 minutes into ride clutch lets go. Pull the lever to come to a stop and it pops to the bar, no clutch. Luckily nothing in front of me and the guy behind me was observant enough to not hit me as I continued straddling the yellow line downshifting and chirping the tire as I got to first and limped back home. Missed my turn didn't want to lock up the brakes and stall it out.
First time I've had time to get it out since back together. Go figure. Back apart it comes. I really believe it hates me and I need to trade it in.
  #49
Old 09-23-2015, 05:51 PM
tmanbuckhunter's Avatar
tmanbuckhunter
tmanbuckhunter is offline
Any idea what happened? Didn't put something back together right? Break the clutch cable? It happens.
  #50
Old 09-23-2015, 06:17 PM
br549A1's Avatar
br549A1
br549A1 is offline
Pulled the cover. Found this all unscrewed. Went to tighten it and the c clip popped out and something shot across the floor. It's jammed the adjuster will not go in and the cable has about two inches of slack. I have no idea what went wrong. Something broke. So f-g annoyed. I guess I have to pull the trans cover and check the clutch cable on that side? Not even sure anymore. It was shifting and running just fine. Edit... I see what shot across the floor now. The clutch piece that holds the clip in. Mother F-r I give up. Anyone want a low rider.
Quick Reply: Primary leak?
