Crank Runout
Crank Runout
Trying to help out my buddy he has what appears to be a shake when letting off the throttle. The bike is a 1985 flht with quite a few miles on it. He had someone replace the belt on the bike and he had found that the comp nut was quite tight and had to use a 2 foot pipe on the end of a large ratchet and socket so took a bit to ease it off.
Couple questions as I have to ask and would be first for me but is it possible to bend a crankshaft by removing the compensator nut with the clutch basket and chain locked used the nylon step tool at the basket end?
He had a guy check the runout on the crank and found it to be .006 thou although I'm not exactly sure where the measurement was done other than it was done on primary side with clutch chain and sprocket removed.
My Softail 1984 to 1999 manual shows:
Flywheels Runout ( @ Rim) to 0.000 - 0.010 inch with a wear limit of 0.015
Runout ( @ Shaft ) 0.000-0.002 and wear limit of .003
Where is Flywheel Runout ( @Rim ) measured and where is Runout ( @ Shaft ) measured ?
Thanks
Thanks
Is it possible to bend the primary side of the shaft just by loosening a stubborn comp nut?
Unlikely that you would do that, them flywheels are pretty tight and the whole set up is designed for you to take a pipe to the comp nut, it's at 160 ft/ibs and Red Loctited.
Shakes and stuff are often motor mounts.
Crank runout can give you some random figures if checking it with the motor assembled, it's best done with the crank on forks or whatever device your engineer uses to check runout.
Nice to be missed...I have been busy at the day job plus dealing with several major issues all at once....a stalker, having to go through a withdrawal programme caused by my doc keeping me on some nasty prescription meds for waaaaay too long, an ankle rebuild and winter...not that we really get a winter but everything is getting sorted ready for summer
