92 FXRS running horrible
Took a little break from trying to figure this out,so far I have changed the ignition coil,changed the main jet and cleaned the slow jet, changed the spark plugs, cleaned the inside of the tank and the carb. I also put on a different carb just for grins, none of these have helped. Tried to start it up yesterday after changing the jet and it wouldn't start even with the choke. Would it be possible that something like this could be related to an intake leak? Or potentially air/fuel mixture being off?
69Shark
03-13-2007 12:07 PM
