Wiseco 93.4 ci Big Bore Kit for 1340 Evo
Old 06-12-2015, 08:13 AM
Lucky Luke's Avatar
Lucky Luke
Lucky Luke is offline
I appreciate all that. I was just interested because in comparison to the Axtell 97 kit I have heard nothing about this kit at all. Nothing good or bad. I have not heard of anyone having problems with the Axtell.
I've seen talk that the iron cylinders hold liners straight better than alloy and that some cheap alloy cylinders distort or come distorted, but nothing about re-using the stock ones.
I like the sleeper element of this kit.
Boring to 3.900" would leave about .150" to .200" (4 to 5mm) on the case wall at its thinnest but there's plenty of meat around the rest.
What dimensions do you need to bore to for the 3-5/8" bore S&S Sidewinder big bore kit? S&S say
Bore head to 3.878" to 3.880" diameter by .200" deep. Measure depth from head gasket surface to bottom of cut.
NOTE - We normally take three cuts to bore heads, 3.800" diameter, 3.850" and final size 3.879".
And that's fitting Shovel and Pans too.
The difference is between 3.879" and 3.900" is 21 thou or half a mm.
Would that be a critical weakness?
Old 06-12-2015, 08:24 AM
Lucky Luke's Avatar
Lucky Luke
duplicate - delete
Old 06-12-2015, 08:42 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,868 Likes on 2,430 Posts
Wink
You can have a sleeper with a stroker crankshaft, which bolts straight in with no/minimal machining required! That's a well proven upgrade which some of us have experience with.......
Old 06-13-2015, 08:34 AM
Lucky Luke's Avatar
Lucky Luke
Why? It's all just down to money, to be honest.
I can do much of the work myself, according to S&S boring out the cases is less than an hours work with the right jigs (they actually say half an hour).
And I'm just interested in this kit as I had not heard of it before.
Speaking to shops, I find they have a tendency to push what they have used before/is easiest/make best profit the most.
Strangely, no one seems to know about this kit.
Old 06-13-2015, 11:44 PM
Jasper86's Avatar
Jasper86
Jasper86 is offline
wouldnt do it with a stock crank, especially going for 100+ hp/tq
i twisted mine, destroyed the engine in the process (rod bearing disintegrated, pistons hit the heads, flywheels hit the cases, basically destroyed everything south of the head gaskets...heads are salvageable as they were never cut, and saving them for a later evo project (we all want second/third bikes)
long story short: isn't worth it unless you wanna do something no one else did (and no one else does it because it isn't cost effective).
parts are gonna cost you $2-3k easy, another grand in machine work wouldnt be tough to imagine. whats the point, when for $5k you can get a 111/113 from S&S with a 2 year warranty.....and have the same (or more) power.
Old 06-14-2015, 11:40 AM
Lucky Luke's Avatar
Lucky Luke
I had no specific power aims, I figured I'd be getting less than an 1hp per cube therefore I had reckoned on an modest 80 - 85 hp max. Thought a more square engine might rev a little more quickly and it be cheap.
How much is the standard crank recommend for? Is it worth welding up while it is out?
Mine's relative new. It was redone may be 8,000 miles ago by the previous owner. But unfortunately just stock.
Now that guy was crazy IMO ... he bombed his engine, or ran out of oil, and then went to a official dealership to have it all built back to stock, using only stock H-D parts. Not a single piece of S&S, not even a breather or Torrington bearing.
Old 06-15-2015, 09:11 AM
tmanbuckhunter's Avatar
tmanbuckhunter
tmanbuckhunter is offline
You don't really weld Evo cranks... these are not TC's.
Old 06-16-2015, 07:00 AM
Lucky Luke's Avatar
Lucky Luke
What is the weak point to look out for.
I've never heard of engine bombing in the way described above but most people I know ride stock or TCs now.
Old 06-16-2015, 09:47 PM
Jasper86's Avatar
Jasper86
Jasper86 is offline
sometimes, it happens.
I was told in ~ '95 or so, harley stopped "hand building" cranks, and instead spec'd all parts to be within .0005" tolerances....so that way the total allowable tolerance between all parts would be within their original spec.
my crank twisted, and wiped out the rod bearing on the rear cylinder....why? Im not 100% sure. I will say that after I split the cases, I was able to break the crankpin nut loose with a 3/8 ratchet (not in a jig, not clamped). seeing as its SUPPOSED to be torqued to something like 350lb/ft, I have a feeling something loosened up.
prior to the failure, the bottom end on this bike has NEVER been apart (had no reason to)....**** just happens sometimes.
Chopper Nate
Engine Mechanical Topics
04-30-2019 08:45 AM
Contrails
EVO
02-02-2012 08:30 PM
hotrod351
EVO
10-12-2008 09:46 AM
chopper_53e
Exhaust System Topics
02-11-2008 05:00 PM
TxMoores
10-19-2005 07:35 PM
Quick Reply: Wiseco 93.4 ci Big Bore Kit for 1340 Evo
