Where is it coming from????
Old 06-03-2015 | 08:05 PM
Pothole914's Avatar
Pothole914
Default Where is it coming from????
I'm getting this carbon on my plug wire but, can't find out where it is coming from. Anyone ever seen this? I'm befuddled....
Old 06-03-2015 | 08:25 PM
Harleycruiser's Avatar
Harleycruiser
Your spark plug has a compression leal between the insulator and metal.
Old 06-03-2015 | 08:32 PM
GraemeR's Avatar
GraemeR
+1 on what he said...Its easy to see.
Old 06-03-2015 | 08:55 PM
Pothole914's Avatar
Pothole914
I thought that also. Switched plugs from front to back. Front one now has NO carbon, the one that was in the front, well, you can see it.
Old 06-03-2015 | 09:13 PM
Harleycruiser
Leaking here.
Old 06-03-2015 | 09:17 PM
Pothole914's Avatar
Pothole914
If that is the case, why would it leak in the rear cylinder but, when I put it in the front cylinder, no leak????
Old 06-03-2015 | 09:26 PM
Harleycruiser
So is the rear cylinder still leaking with the other plug in it?
Old 06-03-2015 | 09:34 PM
golfblues's Avatar
golfblues
Very confusing on what is leaking. Sounds like the front one originally was leaking so you moved it to the rear and its still leaking in the rear and the front is not leaking anymore. That would mean it's the plug.
Old 06-03-2015 | 09:37 PM
Harleycruiser
Yea I am confused also. All this information should have been in the first post.
Old 06-04-2015 | 05:01 AM
Pothole914's Avatar
Pothole914
Ok, let me try to clarify. The pic is of the rear cylinder. After looking things over, I couldn't find where the carbon is coming from. I, like you thought it was coming from the spark plug. To be sure, after cleaning up the plug, I swapped the plugs, rear to the front, front to the rear. The plug that was in the rear and now in the front remains clean. The plug that was in the front (and clean) is now in the rear and appears to be leaking now.
Quick Reply: Where is it coming from????
