Larger S & S jugs on a stock lower end.
Old 12-25-2020, 09:05 AM
Max Headflow's Avatar
Max Headflow
Max Headflow is online now
Received 6,040 Likes on 4,074 Posts
Originally Posted by Prot
There is a point where when the bore exceeds a certain size, you have to bore the cases. The large bore engines have reinforced cases. If you exceed a certain bore size on a stock HD case, it becomes weak. In my opinion it is ok to go a little larger on a stock case, but then after that, if the intention is to stay with a stock case, your efforts are better spent on better flow in and out, better fuel system, etc to get the most out of the displacement you have.
Generally a longer stroke engine will turn less rpm's but will have more low end torque. That principle is what Harley engines, especially shovelheads and Evo's are designed on.
Japanese bikes, especially crotchety rockets use very short strokes with a larger bore. They have five digit redlines. They tend to produce more high end horsepower and less low end torque.
I may be wrong, but I think TC88's use a larger bore and shorter stroke than Evo 80". That is part of why they lost the characteristic sound and feel different. The TC96 and TC103 may have rectified that but I am unsure.
If you are thinking it's the stroke itself that brings about the low end torque, you'd be wrong. Displacement makes torque. Cams, headflow, pipes dictate where the power will be. Bumping compression is a cure all if done correctly. The thing is that many HD riders think that longer stroke make more low end torque so HD gave it to them on the later TC models to extend the motor generation life and save money on the cost of upgrade. Only had to change 2 parts, the crank and pistons.
98hotrodfatboy (12-26-2020)
  #32
Old 12-26-2020, 06:45 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is online now
Received 5,476 Likes on 3,650 Posts
MAX.... You a Little late to the party? Or just bored?... But you are correct... Any motor can make really good torque based on the design of the build... Sure more cubic inches is going to help you out, without a doubt... And yeah I'm just bored..... Hope you had a nice Christmas...
Oh Oh yeah and for everybody else you can safely go to 3.8125 cylinder bore on an 80-in Evo..
  #33
Old 12-26-2020, 09:00 AM
Max Headflow
Yeah, it's one of those, I scrolled past the end of one thread into another with the browser and didn't check the dates..
soft 02 (12-26-2020)
  #34
Old 12-29-2020, 03:57 PM
eighteight's Avatar
eighteight
eighteight is online now
Received 5,039 Likes on 2,880 Posts
[QUOTE
Oh Oh yeah and for everybody else you can safely go to 3.8125 cylinder bore on an 80-in Evo..[/QUOTE]
Respectfully requesting clarification.
thats 97 cid with stock 4.25 stroke
Im assuming this is with case boring and aftermarket cylinders?
stumpy13
EVO
08-22-2014 02:03 PM
motohead20
EVO
04-15-2013 12:21 AM
nellis003
Exhaust System Topics
02-15-2013 09:51 PM
travistodd1
Engine Mechanical Topics
01-25-2013 04:32 PM
Faast Ed
10-11-2010 09:36 PM
Quick Reply: Larger S & S jugs on a stock lower end.
