turn Signals Lit But Not Blinking..
Well, this is getting very annoying! After much troubleshooting I have found that the black ground wire at the Turn Signal Module isn't grounding.
I don't know where the loose or broken end is as the wire disappears into a large bundle of wires that goes to the right side, side-cover area. The ground also ties into other ground wires according to the schematic.
Has any of you had this experience or know where to look next?
If you can't chase the wire look for any place the bundle of wires moves or rubs on something. You can also try chasing down a ground wire from something else in the area the bundle ends. You should be able to spot where the grounding point is. Also did any work happen on the bike if so check the area for a broken or disconnected wire.
Hope this helps
Hope this helps
Received 4,361 Likes
You could always cut it out and ground it separately.
I wouldn't spend a minute trying to chase a broken ground inside a loom. You can never have too many grounds. Add one and ride.
The two grounds at the seat are good.
I don't know where the ground from the speedo and tach meet up with the ground from the TSM. Probably under the tanks...
Everything is working (grounded) but the turn signals.
How can I "Ohm Out" the wire if it is broken or disconnected between the two ends?
