Oil reading
I'd guess you're fine. Your oil tank is under the transmission, so it would make sense that oil from the cooler may be settling there when the bike isn't running. Check the oil level when warmed up and ride on. I would.
If there is a better way to plumb the cooler in and avoid this, I'm sure one of our members more experienced than I will suggest it pretty quickly.
