hELLO ALL,MY 97' RK has a pretty loud squeel from the drive belt on decell in all gears but its worse be fore complete warm-up.Do you guys think this is a too loose or tihht situation?Its lined up and on center but the noise is getting on my nerves.Thanks,Skip
Had same issue, dry graphite spray will help you out ,treat it a few times.(Napa). As far as tension goes, adjust belt to specs not sound. Mine squealed on acceleration, opposite of yours, good luck....
Drive belt should run on the inside going forward, outside going back. How many miles on the belt and pulleys.
If the chrome is wore off the rear pully or starting to chip off it is wore out and will squeek.
