how to remove speedometer cable? 89 fltc
I have a 89 tour glide classic....trying to install a new speedo cable...I got the top half out of the speedometer, but nothing is happening but spinning on the drive unit? the new one has threads, so I assume the bottom does too, but ive tried twisting at every point and its doing nothing but spinning.....is it a one piece drive and cable on the oem part? or what am I doing wrong?
Received 4,361 Likes
i used shrink tube, it's used for sealing wires that are soldered together. get some that's big enough to fit over the drive and cable, apply some heat and it will form to the cable with a water tight seal.
