Modifying a windshield???
Old 04-22-2015, 08:04 PM
RidemyEVO's Avatar
RidemyEVO
RidemyEVO is offline
I used a jigsaw with fine tooth blade and cleaned it up with belt sander.
Old 04-22-2015, 08:55 PM
wombat457's Avatar
wombat457
wombat457 is offline
I've got a jig saw and router, but sounds like the jig saw is the better option along with painters tape or similar. I can only try and see what happens
Old 04-22-2015, 09:20 PM
Harleycruiser's Avatar
Harleycruiser
Harleycruiser is offline
Tape the windshield real good, both sides, and a jig saw is best.
Secret is in the blade, too fine and it melts the plastic that welds back behind the cut.
To course and you take a chance of cracking it, it will jump all over the place.
Go slow, I use a belt sander to clean it up, flame it if you don't like the sanded look.
I use a pen with string to mark my arc on the tape.
Old 04-22-2015, 09:23 PM
wombat457's Avatar
wombat457
Cheers Harleycruiser!
Old 04-22-2015, 11:30 PM
RidemyEVO's Avatar
RidemyEVO
This is exactly the way I did mine. Once you get comfortable standing position and start cutting just don't stop until you get to the other end.
Old 04-23-2015, 12:48 AM
wombat457's Avatar
wombat457
Thanks Lynn, slow and steady right
Old 04-23-2015, 01:49 AM
fox chaser's Avatar
fox chaser
fox chaser is offline
I live near you. Just did one this week. Lexan. variable speed jigsaw, ran kinda slow,fine blade. One thing I'd add. Tape the bottom of saw for extra safety. Sanded by hand. Started with course. worked my way to 800.
Old 04-23-2015, 04:06 AM
wombat457's Avatar
wombat457
Thanks for the tip, appreciate it.
Old 04-23-2015, 04:12 AM
Yankee Dog's Avatar
Yankee Dog
Yankee Dog is offline
Received 2,043 Likes on 1,031 Posts
Make a pratice cut ABOVE or away from the actual line you want to cut. When you get a good feel for it, go to the original line and cut away. YD
Old 04-23-2015, 04:16 AM
wombat457's Avatar
wombat457
I fully intend to "practice" before I start chopping into the wind screen
Quick Reply: Modifying a windshield???
