Ignition coil?
Ignition coil?
I'm assuming my problem is the ignition coil.....but I thought i'd check with you guys.......
Bike: 1995 Evo Fatboy
Riding to work this morning suddenly the bike cut out on one cylinder.
I limped home on one cylinder.
Just checked whether I was getting a spark on the bad (front) cylinder....and no spark.
Changed the spark plug, still no spark. (meanwhile the bike runs on the back cylinder).
Switched over the leads on the coil and then spark at the front and won't run on the back cylinder.
I'm therefore I'm assuming the ignition coil is the problem?
The coil was only new about 5 months ago, and the bike has been laid up for 3 months of that time.
you have a duel fire coil and both plugs fire a the same time every time so its not the coil if you switched the wires and it still started on one cylinder and did not switch the cylinder that was running to the one that did not
Could be the plug wire - could be a mechanical issue - you need to do testing and you need the factory workshop books so when asking about a part, its with the correct name its actually called so help can happen with out guessing what you actually are looking at
Assuming you have a dual fire system, if you move just one end of the plug wire from one cylinder to the other (crossed), and the miss moves, you have either a bad coil or a bad wire. If you move the entire plug wire (both ends) from one cylinder to the other, and the miss moves, the coil is good and the wire is bad. If you can't move the miss with wire switching, check compression.
