just changed my oil. level too full and i dont understand why/how
#121
So you figured showing him the oil relief valve for a Twinkie would steer him in the right direction despite the fact he has an Evo? Right, that wouldn't be confusing at all for a new Harley owner. Why not show him a diagram of a Shovelhead points and condenser? Maybe how to properly kickstart a Panhead?
I'm not trying to go out of my way to be a dick here, but good grief there's as much bad info in this thread as the op-ed section of The Huffington Post. I'm no Evo expert, but I actually own one. I've never owned or wrenched on a Twin Cam so you better believe I won't be telling someone what they need to do to fix cam chain tensioners or diagnose error codes or where the best place is to go for a Chrome Consultation.
#122
(Think this is now correct) Harley motors kept changing over the years. Knuckle, Pan, Shovel, Evo (Evolution), Twin Cam (some call a twinkie or TC... there is also a TCb in the Softails that has two balance cams to balance the engine besides the twin valve cams)
Oil filter to come along was on the EVO probably due to competition. When the Twin Cam came along, Harley went to an internal oil pump and the oil thru the filter and then to the engine. Balance cams on a TCb. EVO oil pump and oil feed system
__________________
__________________
#123
doing a great job without trying, yep all oil relief valves look similar, springloded plunger, been a few years since I worked on a evo , and did forget it was exteral pump , and the relief valve is pretty easy to get at, but if you think a points and condenser look like a relief valve maybe YOUR advice isn't too sounds either.
#124
yeah you don't know oil system from electrical, not gonna play this game with you , I get it, not the best pic I used, but it does show what the oil relief valve looks like but still a good place to start looking for this particular issue.
#126
Grovit posted a problem he didn't understand and was looking for help. He's new to Harley's and hasn't yet learned the in's and out's of his bike and how it differs from other years and models. People posting Twin Cam solutions to Evo problems aren't helping him out any, and will only further the frustration he's having. If you can't understand that SIDECAR BOB, I'm not sure there's anything further I can do to spell it out any clearer.
