Best route to get high performance from my Evo
I have been considering doing some work on my Road King ('97 Evo with carb). The indy that I trust is telling me he recommends high performance heads, valves, springs and cam. New jets for the carb. (around $2200-2500)
What do you guys think of this advice?
UPDATE:...OK, I decided to go with Indy's advice, got him to install S&S high performance heads, valves, springs and S&S 515 cam. Some work on the carb, rejet, etc.
I must say, I am majorly impressed. Really turned on the old Evo...lol!
Next winter, I wanna do the bottom end of the engine to increase the compression, etc.
Thanks
Received 15,753 Likes
Free flowing air cleaner, good tuned exhaust system (not wide open drag pipes), rejet the carb, and a bolt in cam such as EV13 or EV27. Top it off with a dynatek ignition and call it a day. Those few items will make a world of difference without breaking the bank.
Before doing that, do a compression test. If the numbers are low it if there is a big difference between the two cylinders, pull the jugs, bore or hone as needed, fresh set of appropriate rings, mill the heads slightly to get their volumes as close as possible to each other, then reassemble while trying different gasket thicknesses on the jugs and heads and proceed with the mods in the first paragraph.
You would be surprised at what an 80" Evo is capable of with a little massage here and there. The improvements will be greater than what the dyno will indicate in terms of ridability and joy to ride.
Jeff
Jeff
A buddy of mine has a 1996 Heritage with Mild head porting, 9.75-1 pistons, stock springs, ev-27 cam, crane ignition and a Mikuni hsr 42 carb (the mikuni did as much as anything else). Compared to stock his bike screams and gets about 47 mpg @ 60 mph. ( he also has a 6 speed)
That bike pisses me off. I have a 05 Road king with 95", se heads and 203 cams and from a rolling start I can't pull more than 1/2 a wheel ahead of him until after 70 mph.
This is your best bet, unless you really want to join some of us on the slippery slope of the chase for even more EVO HP. If the above isn't enough for you, we'd be glad to help you spend your money.
Received 4,361 Likes
If you really want to get the motor running then $2.5 k is a little light if you are having an indy do it.
Better off just getting an entire engine.
