LED turn signals work... then don't??
88 FLST with a stock wiring harness. I have Alloy Art leds up front and a Russ Wernimont (sp?) led cateye with integral run/brake/signals. I have a led type flasher installed. Like I said, everything else is stock. When I first turn on my ignition (new build, first time testing electronics) the signals work fine. I hear the flasher "click" and like I said, both front and rear signals work great. But after a minute or so, they stop working. When I hold either signal button in, they light up and just slowly fade off. No more flashing. Shut if off for a few minutes and it repeats - first they work, then they stop.
I've been referred to Badlands/NAMZ for a load equalizer. I'll call in the morning. Can someone just explain to me why they initially work but then stop? I think I'd feel better if they just didn't work at all. Thanks in advance for your help.
Thanks for replying! So initially its sufficient but then becomes insufficient? They supplied an equalizer with my tailight but its designed for the 2001 & later factory harness.
Thank you for the reply. That's what's confusing me. If its not working right, wouldn't it not work at all? Not work at first and then stop working??
A "regular" flasher is dependent on load to work correctly...an "electronic" flasher needs no load to work..so using one eliminates the need for "equalizers" which are just resistors.
https://www.superbrightleds.com/more...pEBhoCSHTw_wcB
You have a led type flasher installed, what does it do with the normal one. What I was gettin at was;think of a flashlight battery going dead and out,turn off for a while and it will light then go back out again, I think there not being supplied enough current. Might even be tripping the breaker. Too much and they may blink really fast.
I didn't realize you had an electronic flasher...don't think you would hear one click...are you sure you are not hearing the breaker? You have one of 2 problems...either the flasher is bad, or it is not wired correctly.
