Cylinder Stud Torque
Old 03-15-2015 | 08:15 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by kp877
What year is your manual? If yours had the shoulder up from the factory then it's different. At some point they switched to shoulders and changed the instructions to shoulder down
The one I was looking at covers '84 to '99 Softails.
I notice that in your instructions it tells you to drop a ball bearing down the stud holes and then tighten the stud on top of them.
Mine doesn't use the ball bearings.
Old 03-15-2015 | 08:20 AM
texashillcountry
Dirt don't hurt
Originally Posted by glidein wide
Did they change to shoulder bolts for perfect jug alignment at some point? If so the gaskets must have changed also. And does that mean the bottom of the jugs would be opened to accept the shoulder, making all years NOT interchangeable?
'84 and early '85 used different cylinder stud bolts and the heads from those years won't fit over the newer cylinder studs.
Old 03-15-2015 | 08:57 AM
glidein wide's Avatar
glidein wide
Did not know, was there a problem, mine 86
Old 03-15-2015 | 09:00 AM
texashillcountry
Dirt don't hurt
I din't either until a friend of mine wanted me to put a top end gasket set on his '85.
Old 03-15-2015 | 07:30 PM
tmanbuckhunter's Avatar
tmanbuckhunter
Sometimes they installed flange up. The later way, and the correct way, is to install flange down. That may be where the different heights come from.
Old 03-16-2015 | 12:23 AM
apples402's Avatar
apples402
Originally Posted by texashillcountry
The one I was looking at covers '84 to '99 Softails.<br />
I notice that in your instructions it tells you to drop a ball bearing down the stud holes and then tighten the stud on top of them.<br />
I read the instructions to place the ball bearing in the head bolt, then tighten the bolt on the stud, then run the stud down into the case. FWIW all my studs had the shoulders up so I flipped them, my 92 manual also has the length method, not torqued, seems hard to torque without bending them. The ball bearing is to keep the head bolt from locking on the stud and the rag is to keep the bearing out of the cases upon removal of head bolt.
Old 03-16-2015 | 08:40 AM
SeaZund's Avatar
SeaZund
is the purpose of the ball bearing to serve as sort of a crush washer, allowing a certain amount of "squish"?
Old 03-16-2015 | 08:53 AM
br549A1's Avatar
br549A1
it's to keep the bolt from locking onto the stud so you can remove it once you get the stud torqued. I used a chunk of Allen wrench since I couldn't find a ball. Worked perfectly.
Old 03-16-2015 | 08:55 AM
98hotrodfatboy's Avatar
98hotrodfatboy
The bearing keeps the head bolt from locking onto the stud, easier removal to help prevent the stud backing out.
Old 03-16-2015 | 12:51 PM
RLH3175's Avatar
RLH3175
Early 87 and older, no shoulder. Late 87 to 98 has a shoulder, according to my manual.
Quick Reply: Cylinder Stud Torque
