Wrist pin clip fail
Wrist pin clip fail
Damaged front cylinder in my 80" EVO when the clip fell out but it was wasn't ran for long like this. I thought I had them in tight but was wrong on one as it came out. This is a fresh build with maybe a mile on it.
The cylinder has two groves from the pin and is likely a write off from what my machinist said, he figures it is oval shaped now.
My question is about replacing just the front cylinder with another good used one.
The barrels were both stock bore 3.498" so the rear one is like new. I would have the pair bored out a bit as I have to buy new pistons anyway. I just hate buying a pair of cylinders if I can just install a single.
I am getting my bottom end rebuilt and balanced as the pin jammed and now it has quite a wobble so I would like to save money where I can.
Received 4,361 Likes
Just a thought.
D_gyver - I thought I would be able to bore 20 or 30 thou but my machinist thinks the cylinder is out of round and would cause issues. I will look at it again with him to make certain.
texashillcountry - I just happen to have a fresh can of wrinkle black that will come in handy if I do replace the cylinder.
if hes checking the cylinder on the bench it will be out of round he has to use torque plates to check the cylinders
