Adding kickstart to an Evo.
Old 02-08-2015, 10:41 PM
musicnbikes's Avatar
musicnbikes
musicnbikes is offline
Default Adding kickstart to an Evo.
Have any of you guys added a kickstart to your evo? I Am thinking about it, I just don't know how Involved it is. Any info, much appreciated. if you've done it, post some pics.
Old 02-08-2015, 11:42 PM
Hebrew Battle Rifle's Avatar
Hebrew Battle Rifle
Hebrew Battle Rifle is offline
Harley Davidson put a kicker on my Softail at the factory.
Old 02-09-2015, 01:06 AM
misfitJason's Avatar
misfitJason
misfitJason is offline
Received 1,059 Likes on 672 Posts
I had one that I put on my five speed and ran it as kick only for about four years....when my evo was a rigid. I am assuming that your bike is a stock evo. For me I had a dyna s ignition (still using it) which allowed for kickstart and the appropriate coil. The pipes needed to be changed to ones that fit a 1984-1985 style with kickstart. Not too hard to find. As far as the kit I used :
http://www.jpcycles.com/product/620-437
it worked pretty good. I will say that it did stick out pretty far though. I would recommend the rivera kit:
http://www.jpcycles.com/product/602-622
tbeatybeaty (08-30-2021)
Old 02-09-2015, 01:11 AM
misfitJason
My bike back when it was a rigid and kickstart
Old 02-09-2015, 07:29 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,868 Likes on 2,430 Posts
Good grief no! I did my time kicking a shovel for many years thanks. However Baker makes a conversion kit if you must!
Old 02-09-2015, 12:13 PM
glidein wide's Avatar
glidein wide
glidein wide is offline
The main shaft has to be changed out with the one that comes with the kit. This means total deconstruction of tranny for the most part. $500 approx for kit or swap tranny with new 5 speed kicker for $1300 and hold on to your old one. It's time and labor versus money.
Old 02-09-2015, 12:23 PM
glidein wide
Part #65 would be the main shaft
Also as Jason said probably exhaust must be changed more than likely.
I have the same exhaust as hebrew does to clear it.
Old 02-09-2015, 04:15 PM
misfitJason
Exhaust is a deffinate change. Old stuff won't fit with the kicker
Old 02-09-2015, 04:22 PM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is offline
Received 20,325 Likes on 5,874 Posts
And the fun part is, virtually no exhaust manufacturer claims that their exhaust will fit an 84-85...they all say 86-99...I have run several exhaust that said they only fit 86-99.
Old 02-09-2015, 05:50 PM
glidein wide
So true, probably because some 84's had shovels and some had new evo. Which of course wouldn't fit both but when you know what you got you know what should work. It's been fun learning what fits an 85-86wide glide, kinda like a mutt but I like it.
Quick Reply: Adding kickstart to an Evo.
