Carb Confusion
I know the Mikuni guys like them. There are more adjustments to deal with it though. S&S carb is very simplistic. I tried one on mine when I was having some random issues with running but took it off after the reduced mileage and I found the real problem cam sensor causing random misfire. I love my cv. I tuned it with the info from nightrider. I didn't cut the spring and I used a smaller bit to enlarge the hole in the slide. I'll probably here some flack from drilling slide but the carb has performed flawless.
I went this route below. Best carb I have ever owned. I did have an S&S and it worked great and was a snap to work on. However my mileage was worse. Just my experiences.
http://www.ebay.com/itm/HARLEY-DAVID...#ht_1751wt_854
I like S&S. It's a much simpler carb and easier to adjust. It comes with good instructions and great support.
As far as bang for the buck, I think the Mikuni wins. EZ kits are very reasonably priced. S&S is more expensive as you need a kit with intake manifold and air cleaner. Either will run great.
Received 5,440 Likes
I have the Mikuni on my 97 Wide Glide and a S&S on the 91 1200 Sportster.
Both tremendous improvements over stock. The CV on the WG had all of the HiPo improvements, the Mikuni still blew it out of the water.
Which one is better? I like them both in their current applications. They are both good products. Money no object, probably go with Mikuni.
Side note, depending on your custom tastes, S&S seems to have more options for air cleaners etc, Mikuni has some options but I feel less. But if you are just going to run what comes in the box, this is a non-issue.
