96 EVO 80cuin cam change
I recently bought a 96 FXST Softail and just about done with maintenance and mods. I am currently focusing in the GO department by replacing the cam with Andrews EV27.
The bike build https://www.hdforums.com/forum/softa...ting-carb.html and few engine mods that are complete:
o Modified CV carburetor by Killer motorcycles
o Replaced Screamin Eagle iridium plugs
o Replaced Screamin Eagle plug wires
o Serviced K&N air filter
o Modified air intake housing
o Replaced breather bolts by Sevin sin choppers
o Installed LSD radius exhaust with baffles and lollipops
o Replaced all fluids
Last time I was in the stealership for a spark plug wires, the lady in the counter took 30 minutes just to get the right item . I used the for part numbers but I am not certain if its for the 80cuin. Before I ask the parts personnel again for a "easy install, tapered pushrod," I humbly wanted to know the parts and part numbers for this project. Thanks in advance.
1. Andrews EV27 - 291127
2. Screamin Eagle push rods (Easy install, tapered, and chromoly) - ???
3. Torrington cam bearing - B138
4. Nose cone gasket -???
5. Screamin eagle ignition module -???
6. anything else I'm missing -???
I've done business with these guys with no problems. Plus they have alot of overhaul stuff for the 1340.
http://hastingsmotorcycleparts.com/C...-Twin-G230.htm
Also what about your roller lifters? Your going to replace them right? Check out Amazon for S&S stuff, you'll save alot compared to ebay and others. That's what I did and saved about 400 on my top end replacement. Good Luck......
80" experience
The EV27 is s good cam but l would definitely go with S&S for the lifters and pushrods and while your at it for $20 I would get the lifters spacers H2LT. SE ignition is good but a lot are going to the Dyna 2000i.
For the cam though I would go with a woods w6 it has a little more lift and overlap than the EV27. and with a.030 head gasket it will perform very nicely.. and its still a bolt in cam.
The thing I like best about the W6 is that it is a good base cam for various levels of builds, so if you start out with a little cash for a build do the cam and later you can do another stage like heads and when you get more cash you can add a bore job and pistons. Very versatile.....and capable of mid 80's for hp and low 90's for torque.
