FXSTS Rear wheel vs FLSTS
I'm looking to put a spoke wheel on my 1999 FXSTC, but I'm a little confused by the wheels I see on EBay. Are evo era Softail FX rear spoke wheels the same as the Softail FL?
Also, it appears those wheels came stock 3 inches wide. I have seen some 3.5 wheels on Ebay, will 3.5 work?
Thanks
Beary
Thanks
Beary
Received 4,361 Likes
I have had these ebay special (ultima wheels) on my bike since March 2011. They have been great but here is what I did.
· I had the end play checked at a shop (even though they claim this is set). I also had the bearings and replaced with higher quality as well as the seals.
· I then took each wheel and painted an enamel clear where each spoke meets the rim (yes this took forever). But after many rain storms and washing the bike I have zero rust and the wheels run great. They also polish up great.
I know this may seem like a bit much BUT the wheels are cheap and all this was very easy to do. Also I had to get the tires mounted anyway so checking the endplay and getting bearings was no big deal.
[QUOTE=2006FLST;I know this may seem like a bit much BUT the wheels are cheap and all this was very easy to do. Also I had to get the tires mounted anyway so checking the endplay and getting bearings was no big deal.[/QUOTE]
Great response, thanks. I keep seeing these cheap Ultima wheels and wonder how good they really are. I will keep your suggestions in mind as I look for a wheel. I would have never thought about painting with enamel clear.
One reason I'm kind of considering Ultima is I'm thinking about an 18 inch wheel to show off more wheel. Not sure I will go that way as your bike looks really good.
Beary
Beary
