Priming the oil filter?
Is it necessary to prime the oil filter on the Evo engine at oil change?On my Softail the oil goes from the tank to the oil pump, oils the engine then to the filter,on to the oil cooler and back to the tank.Having the fresh oil from the tank to the engine firstly means it's not so important to prime the filter?Thanks for your advice.
Received 4,361 Likes
When you change your oil and fill the tank by the time the oil filter is full your tank has dropped a very small amount.
I always prime mine. I always prime an inverted oil filter on whatever it goes on including my old P30 motorhome chassis with the GM 454 and the Volvo V70. When I worked on aircraft engines we always primed filters that were inverted and it seems to makes sense. It gives the paper element time to get good and soaked, it what seems to make sense to me anyway.
