How long does a harness last?
Received 4,361 Likes
The harness on my '77 Superglide lasted 'till about 1980 or 81,when I pulled it all off,threw it in the garbage and rewired the bike.Real simple when there was just points ignition,charging system,headlight and taillight,and brakelight.
My '61 Studebaker still has it's original wiring,well 98% of it.
I used to build catv systems and I know the cable for that is rated at 27 years.
I don't know what the wires in the harness are rated for.
I damn sure don't have the correct wires for it.
I don't think there is any such thing, for a wide variety of reasons. My new 1974 FX started giving problems when only a couple of years old, due to the wiring being of marginal length IMHO. My 1977 BMW. also bought new, started giving trouble after 8-9 years, due mainly to flexing of the handlebar harnesses. My 1990 Glide, bought new, is still on it's original harness, although it has been adapted quite a bit.
As for rewiring a bike, there are a couple of products I have come across that help to make it easy. They both use a central magic box, inside which reside all the basic functions a bike needs and into which one simply connects wiring for each switch/function. I have even considered using one myself and an occasional HDF Evo member has already done so.
Thunderheart is one of these, marvellous piece of (expensive) kit.
In the 70's and early 80's Harley started using quick connects with no moisture protection, the bikes were fire hazards right out of the box...a more modern bike with waterproof connectors, the wiring will outlast the bike if not butchered.
