Not another cam thread😃
every one has there own reasons and opinions for the cams they choose. the three main three cams were already listed by previous posters. IMO the v-thunder should not be in the list just because of known quality issues you get what you pay for. as far as the W6 its probably not the cam for you. it really likes compression at the very least your going to need .030 head gaskets. or it will be very oft on the bottom.
so your only real choice is the EV27.
also the EV27 will benefit from a head gasket compression bump as well.
Probably because I read about excessive valve train noise from the EV27, it needs compression bumped to see the real benefits and works best in higher RPM's that I don't ride in. Just trying to see if any of it is bullshit or real. I've emailed Andrews to get their opinion but I know the guys here have real experience and I trust (some) of their opinions I only want to do this once and want to do it right the first time
Here is what Andrews tech support had to say. I gave them the same information I gave you guys. I'm not trying to over think this just want to make sure I buy the right cam the 1st time around. I'm halfway tempted to open my WideGlide up to see what cam is has because it's perfect. Then again, I have no idea what other engine work was done to it.
I like this statement.. but just slapping a cam and lifters in is not the right way to do it. its the cheap way! the EV27 and W6 are both known for there torque gains. and there both known for there valve train noise more so on the W6. that's a price you have to pay for performance with more aggressive ramps. if you hear lifter noise you have a problem that's not normal. if you hear the valves slapping the seats from the aggressive ramps that's normal and there's nothing you can do about that.
both of these cams rely on velocity to fill the cylinders with air and fuel but that come at a price to the compression ratio. your stock motor has a CR of 8.2:1 with a stock cam your corrected compression ratio or CCR would be 7.9:1 and with a EV27 it will drop to CCR 7.7:1 and the W6 would make it CCR 7.3:1 witch translates to soft on the bottom. to gain back what you lost at the very least a .030 head gasket will bring the CCR back to 7.95:1 on the EV27.
Received 4,361 Likes
