Ultima steel breather gear any good? Cam swap advice
Old 11-13-2014, 02:44 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,863 Likes on 3,026 Posts
Originally Posted by SeaZund
the S&S install instructions say to back off the push rods (if adjustable, otherwise remove them) when installing this reed valve; how come?
i am sure the guy who wrote that is back working at wal mart selling harley T shirts AGAIN
Old 11-13-2014, 04:39 PM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,361 Likes on 1,953 Posts
I would think it is so you can get the cam chest off.
Unless you know Spanners trick of putting the notch of the cam at the 5 o'clock position.
Old 11-15-2014, 03:50 AM
Spanners39's Avatar
Spanners39
Spanners39 is offline
He does now.....
Old 08-27-2020, 06:02 AM
johnnyjellybean's Avatar
johnnyjellybean
johnnyjellybean is offline
Can you elaborate please?
Old 08-27-2020, 07:14 AM
Adam76's Avatar
Adam76
Adam76 is offline
Originally Posted by misfitJason
Was shopping for the s&s steel breather gear and came across this one. I searched on here but didn't come up with any results. They can be had for about 30 bucks through jireh. I have also looked at the jims version, sifton version, and s&s. They all look the same to me. Also will my shin work for these or is it best to get a shin kit being its a new breather gear like the s&s comes with? Looking for thoughts and advice. My cam swap is going in and I am shopping around for the bearing installer/puller tools. I already have the ev27 and I was contemplating going with a s&s oil pump at the same time because my check ball seat needs attention I am guessing judging by the oil coming from my breather. I already replaced my check ball and spring which didn't help.
Originally Posted by johnjzjz
when no issue exist i will use the ultima breather they are imports but are pretty good
the S&S reed breather is the one i like it does the job the spinning one cant do, and in all the motors i have used them in the oil control is way better - some the issue is completly gone for 50,000 miles
yes you need to correctly shim the new breather and its not one shim fits all - the reed breather uses a spring to hold it in place as it does not spin with the gearing
I just went through exactly what you are doing with my ev27 cam set up. After much debate I made an educated (IMO) decision to go between to the two options and choose to fit the Ultima steel breather gear. I was surprised at the quality and finish and fit of the breather for less than half the cost of the s&s one . I still had to shim it, but luckily it took the .130" shim I had already ordered.
good luck, and let us know how it turns out. 👍
Old 08-27-2020, 09:56 AM
texashillcountry
Dirt don't hurt
I haven't done this yet but supposedly if you take the cam sensor (or ignition pickup if you prefer) out then remove the cup and put the notch that the cup fits in to the 5 o'clock position (you will have to hold the cam in place or it will come out with the cam chest) then you can remove the cam chest without having to remove the lifters or pushrods.
fergerburger
Shovelhead
14
10-04-2017 10:47 AM
Racepres
Shovelhead
16
06-25-2016 03:21 PM
Fernf5
EVO
05-06-2012 09:36 PM
trigger1911
Exhaust System Topics
10-26-2009 09:29 AM
skidooer
09-05-2006 12:16 PM
Quick Reply: Ultima steel breather gear any good? Cam swap advice
