starter or solenoid
Received 4,361 Likes
A friend of mine just had the same problem.
There is a shaft in the solenoid that has a big washer on it.
The shaft in his had gotten corroded and wouldn't spin.
He took it apart and cleaned the shaft and all is well again.
He has an '85 FXEF if that matters.
Good news! Unless you take a long run on your new battery, to fully charge it, disconnect it and charge it overnight with a proper battery charger. Despite what the makers say they are not fully charged when we buy them and will give better service that way, especially if you normally only take short rides.
