Mark this thread as Unsold
DynaTek ignition and software
DYNATEK 2000-HDE Single/Dual Fire Programmable Digital Ignition System- DD2000-HD1E8P. Will also throw in for free DynaTek DIPK-3 programming kit ( no idea how this thing works never used it)
$95
Dynatek 2000-HDE Single/Dual Fire Programmable Digial Ignition Systems-8 Pin - DD2000-HD1E8P
- Dynatek is the performance leader for quality electronic products in the motorcycle industry. With the help of top racers and motorcycle builders around the world, Dynatek has worked to create the electronic products necessary to support the modern motorcycle
- Upgrade the electronic advance ignition found on late-model Harleys with this plug-in system
- Microcomputer-controlled ignitions generate extremely accurate control over the entire ignition process
- Tailor the advance curve and rev-limiter to the specific needs of your particular engine
- Four built-in advance curves cover the needs of stock to highly modified engines over a variety of operating conditions
- Four independent rev-limiter choices from 6000 to 7500 rpm set the exact protection level needed
- Comes with 8-pin connectors as used on 94 and later Harleys; operates in single-fire or dual-fire modes
- Offers a quick curve, which simulates a mechanical advancer for hot rod motors; option to use vacuum advance compensation via a VOES switch and retard mode, which allows selection of ignition retard of 5°, 7° or 10° upon activation of a retard input
- When in single-fire mode, separate tach output wire allows clean tach operation
- Diagnostic LED indicator on the back of the control module assists in trouble-shooting and static timing
xharleyx
03-09-2009 10:47 PM
