looking for a little help
Ok guys, heres the deal, i hate the brake calipers on my 1998 electra glide, they are soft, and just plain crappy, i would like to upgrade to at least a newer style 4 piston caliper, to my understanding, 99-02 retained a 3/4 axle, so i can keep my stock wheels which are 3/4 axle, so my question is to you, will 99-08 calipers, are they all the same, brembos? looking for help...and guidance, thanks chad.
I went over the top and fitted 13" discs and 6-pot calipers, with braided hoses, as my cure, but you will find hoses alone will improve things, also following guidance in the general tech forum on soft front brakes. It has a spelling mistake in its name, but is top thread! Might be worth trying before spending any bucks, as you may need the same advice following any changes you do make!
Where did you get the adapters?
Just Google "harley caliper adapter" and you'll get a bunch of hits. I used the Bikers Choice adapters ($50) because they are just flat chrome with no markings or lettering on them. I don't remember where I got them, but they are available here:
http://www.shopwizardscycle.com/bike...eradapter.aspx
I installed the H-D "Stylized Chrome Calipers" 4-pot units on my bike that I got for a song on eBay, but they are no longer made. I think they look great - they have "Harley Davidson" embossed in black on them. They use the standard 2000-up H-D pads and pins, and they stop the bike far better than the ugly old single-pot black stockers ever could.
You will need longer brake lines, because the adapters move the caliper down about 2" from the normal position. I would suggest installing the calipers and then measuring the lower line length you will need. I bolted mine into place without the front wheel attached to take the measurements. I went 2" over stock and that was just about perfect for the H-D calipers I used.
Don't know about your bike, but I also had to install a completely new splitter under the triple tree on mine, because the stock unit had the small upper steel line to the master cylinder (fugly!) permanently attached to it, and I wanted to use SS lines anyway. I ended up replacing everything with Russell SS lines and chrome fittings. They weren't cheap, but they look and work great!
Here's what they look like on my bike:
All good answers.My bike is an 83 flt,and im still running the stock front calipers and they work fine,The rear however i up graded to the newer 2000-up caliper which works great.I did have to weld a tab to the swingarm for it but that wasnt and hasnt been a issue at all.If youre getting spongy brakes try replacing the lines with braided line first,and replace all the fluid.
Quite right! Except that I reckon my bike plus wife and I with luggage total close to 1200 pounds ready to roll!
hallfleming
01-21-2016 07:47 PM
