Opinions on buying a 98 Road King
There is a 98 Road King available locally that I can probably buy in the 4-5K price range. 46K miles, bike looks great, comes with lots of extras and only needs tires per the owner. He did state (this is where my red flags go up) that the bike will get a check engine light for the first 10-20 seconds of idle, but the light goes out and the bike runs fine. I know Evo's are rock solid, but Ive also read the fuel injection can be problematic. Does this one red light foretell bigger issues or just a nuance of a 25 year old bike that hasnt been ridden much in the last 10 years?
Im looking for a nice easy winter 'cleaner upper' that Ill need to do minimal work on. I dont want to mess with a bunch of electronics but I am capable of basic multi-meter diagnostics and such. Ive been riding and maintaining Harleys for 20 years, so Im not new to the game, I just wanted to hear from guys who own the same model and know what the more common malfunctions and such are.
I picked up a 98 FLHRCI myself when the world shut down. I needed a lot of help and I spent months on the forum learning. But after all that, I am growing awfully attached to her now.
Look for stored codes.
During my first season of wrenching on it, I saw an engine light and the thing stuttered and died. No more light after that. Long story short, engine temp sensor. Easy peasy.
The MM injection is limited but SIMPLE. Just a few inputs need to be verified. Dont let that light scare you I say.
On later model bikes the engine light remains on for a few seconds to indicate there are trouble codes available. You can check to see if that is the case.
Also read this post:
Retrieving Trouble Codes?????? - Harley Davidson Forums (hdforums.com)
The light going on and off indicates a historic fault code. I'd pull up the trouble code using the process IM has in Bingee's link. It's probably not something fatal to the bike, seeing that it still runs. It could be something as simple as a fault generated from a mis-start. Historic codes that do not reoccur will usually clear themselves after 50 restarts.
46k miles will soon be time for new lifters. Probably time for a new fuel filter soon too. Check the base gaskets and rocker box gaskets for leaks as well. I wouldn't shy away from it if everything else checks out. Garageking and I will tell you that Sinister Blue Pearl is the best color for 1998.
I would use the check engine light issue as a bargaining chip on the price. If you take the time to learn the MMI fuel injection system, it isn't that hard.
By the way, Mystic Green/Vivid Black was the best color available for 98. You'll just have to deal with sinister blue. We can't have everything.
carl
carl
