ordered my 21 inch rim now to shop tires
Old 11-05-2020, 09:13 AM
robwlf10's Avatar
robwlf10
robwlf10 is offline
Rim came in lastnight. 20 days later. But looks really good
New bearings and inner spacer as well
guess I’ll have to use the bearing spacers from the other rim to get my run off right. Company said everything should switch from factory to that rim. (DNA) rim. 60 spoke 3.5
Old 11-06-2020, 06:44 PM
Tee&Vee's Avatar
Tee&Vee
Tee&Vee is offline
Check the grease. Last time I bought a room from internet it was brand new but the bearings were not greased nearly enough.
Old 11-06-2020, 09:45 PM
robwlf10's Avatar
robwlf10
robwlf10 is offline
these came dry, ( timken bearing ) with new seals ... im going to pack them myself and use the bearing spacers from the old rim
got in touch with dna and they said everything factory will fit ,bearing spacers,axle spacers and rotor
did a dry fit to make sure after work , everything work as intended , i didnt pack or install the bearings yet .just did a dry fit to make sure everything mocked up
fit like a glove ,also got fender risers for the time being till i get a fender i like
Old 11-07-2020, 06:24 PM
86glider's Avatar
86glider
86glider is offline
Thats a nice looking rim.I like the fact the spokes are sealed and it uses a Timken bearing.
Old 11-08-2020, 06:11 AM
robwlf10's Avatar
robwlf10
robwlf10 is offline
im pretty happy with the rim, i know some say dna isnt a high quality rim
this seems pretty well put together .will see how she holds up down the line
my bike is pretty much a weekend rider,maybe ride to work on nice days so.. debating if i should run a tube or just keep it tubeless i like tubless so if i get something
in there i can plug it to get me home , tube doesnt have that option
Old 11-14-2020, 06:26 AM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,361 Likes on 1,953 Posts
My vote is always run a rim that you can run tubeless for exactly the reason you mentioned.
robwlf10 (11-14-2020)
Old 11-14-2020, 08:06 PM
robwlf10's Avatar
robwlf10
robwlf10 is offline
She’s on put about 20 miles on it so far hopefully ride tomorrow going to be nice
had to order new rotor, and pads for the front no sense putting old rotor and pads in , Plus I’m getting pad rattle.
happy with how she looks
Panheadsrule
07-06-2019 10:24 AM
Dpostle79
06-28-2019 10:58 AM
flyingfrog509
01-16-2017 07:10 AM
lissalee6938@yahoo.com
03-27-2013 07:56 PM
bulldog82098
08-25-2012 08:24 AM
Quick Reply: ordered my 21 inch rim now to shop tires
