Dual Exhaust 1988 FLSTC
Old 11-08-2019, 11:48 AM
Rijan's Avatar
Rijan
Rijan is offline
Default Dual Exhaust 1988 FLSTC
Hey Guys trying to find a dual exhaust set up with fish tails for my 1988 EVO to remove the V&H any one know where they sell it
kb_jag (11-13-2019)
Old 11-08-2019, 11:51 AM
Mountainkowboy's Avatar
Mountainkowboy
Mountainkowboy is offline
Received 1,010 Likes on 544 Posts
Twinkie exhaust works on an Evo.
Rijan (11-08-2019)
Old 11-08-2019, 11:52 AM
misfitJason's Avatar
misfitJason
misfitJason is offline
Received 1,056 Likes on 669 Posts
Samson makes a few of them
Rijan (11-08-2019)
Old 11-08-2019, 11:56 AM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is online now
Received 20,117 Likes on 5,824 Posts
You have to look close and see if it will clear the starter solenoid...that is usually the issue with 88 and earlier softails...
Rijan (11-08-2019)
Old 11-08-2019, 11:59 AM
Mountainkowboy
Never had a softtail, so Tom is probably a better source...lol, direct bolt on on an touring frame thought.
Rijan (11-08-2019)
Old 11-08-2019, 06:18 PM
86glider's Avatar
86glider
86glider is offline
Try Paughco ?
Rijan (11-09-2019)
Old 11-09-2019, 09:15 AM
0maha's Avatar
0maha
0maha is offline
Received 4,675 Likes on 1,663 Posts
I put Paughcos on my '90.
Even though it was supposed to be a direct fit, still ended up needing to fab a bracket (the one that loops over the starter) to make it fit.
Odds are whatever you come up with will require some manner of similar fettling.
Rijan (11-09-2019)
Old 11-09-2019, 09:47 AM
Tom84FXST's Avatar
Tom84FXST
The problem with the 88 softail is the pipe, and the starter solenoid will try to occupy the same space...
Rijan (11-09-2019)
Old 11-09-2019, 09:56 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,866 Likes on 2,429 Posts
In addition to Tom's photos above, I found that twinkie TD pipes fouled the primary chain-case on my Evo Glide. I realise that is a different primary, but be wary of inter-changeability! My twinkie 2-into-1 works fine.
Old 11-09-2019, 10:30 AM
Rijan's Avatar
Rijan
Rijan is offline
Originally Posted by 86glider
Try Paughco ?
thanks!
Quick Reply: Dual Exhaust 1988 FLSTC
