Shinko E270 Tyre Pressure
Old 08-23-2019, 06:48 AM
SimonR's Avatar
SimonR
SimonR is offline
Default Shinko E270 Tyre Pressure
Afternoon
Recently put a set of Shinko E270's on the FLSTN and wonder what tyre pressures people who are running these are using ?
I'm at 22 front 20 rear .... I've seen people recommend lower but just wondered if anyone on here had any real life experience?
Thanks
Simon
Old 08-23-2019, 07:18 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,867 Likes on 2,429 Posts
Exclamation
They sound way too low IMHO. My real life experience of over 50 years riding is that your source of reference should either be Shinko's own data/website or your owners manual. Correct pressure is likely to be around 40psi.
Old 08-23-2019, 07:50 AM
GOGOBECK's Avatar
GOGOBECK
GOGOBECK is offline
I agree with grb... check the manufacturers web site, they should have a specifications page... I usually run the max psi listed or just a lb or two under max psi.
Old 08-23-2019, 08:00 AM
SimonR's Avatar
SimonR
SimonR is offline
I agree it seems low - but bearing in mind the max pressure is 41 on the sidewall and my reference comes from other forums etc
The website doesn't list a pressure ... as these are a 50/60's design the old manuals for shovels etc specified much lower pressures than we run today
Old 08-23-2019, 08:09 AM
GOGOBECK's Avatar
GOGOBECK
GOGOBECK is offline
Shinkotireusa.com has spec charts for the “Super Classic 270” some are 33 max psi, some are 41 & 42 psi, depending on tire size. It appears all of the 16” tires are 33 max psi.
I didn’t see any E270 tires, just the Super Classic 270 series.
I would go with what’s stamped on your sidewalls!
Old 08-23-2019, 08:11 AM
SimonR's Avatar
SimonR
SimonR is offline
Yep - I got it incorrect - 33psi max
I've emailed them
This was one of the reference threads https://www.jockeyjournal.com/forum/...d.php?t=179394
Old 08-23-2019, 08:15 AM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is offline
Received 20,222 Likes on 5,852 Posts
If you look at an old manuals when those type tires were used, they ran 12-15 PSI and many people are doing that now with vintage bikes....
My understanding is those tires are bad to "hop" if you get over 30 psi...
Cool look but I don't think those tires are up to the task of running 70-80 mph all day with those lower pressures...
All depends if you are willing to give up function for form...
SimonR (08-23-2019)
Old 08-23-2019, 08:16 AM
GOGOBECK's Avatar
GOGOBECK
GOGOBECK is offline
This was one of the reference threads https://www.jockeyjournal.com/forum/...d.php?t=179394[/QUOTE]
I don’t think I’d ever use a spec from a 1950’s product and apply it to a 2019 product! Sounds silly at best and potentially dangerous!
Old 08-23-2019, 08:18 AM
SimonR's Avatar
SimonR
SimonR is offline
All depends if you are will to give up function for form...
Yep - That's along the lines I was thinking
TBH I've got the Road King for serious riding so this won't see speeds above 50/60 and more often less ... just for tootling around
I realise there is a compromise using these but I'm OK with that - they seem to grip well in the dry at least
Old 08-23-2019, 08:20 AM
SimonR's Avatar
SimonR
SimonR is offline
I hear you - they aren't exactly 2019 technology though
Quick Reply: Shinko E270 Tyre Pressure
