FXR question
FXR question
Recently picked up a 94 FXR Superglide
My question is it only has the speedometer no tach. How hard would it be to wire in a H-D tach from that model era? Maybe relocate the speedo and tach on a dual Mickey Mouse setup? Just curious if it’s a major pain in the @ss and not worth the trouble? Plan on switching bars to a 12” setup so idk if wiring or extending would be a nightmare to do?
thanks
thanks
thanks
thanks
The tanks are the same and it'll be a simple job to wire the in dash fuel gauge if you want that.
This is the style of dash I'd assume you'd want to use.....I have one that I adapted to my Dyna and also use the same dash on my FXR's.
It's a simple job to go to the mouse ears setup and there are regular FXR dashes out there to replace the speedo dash.
I swapped around and used all Harley take of parts.
I try to use factory stuff as much as possible....There are lots of good aftermarket vendors out there though.
I wound up putting a T-Sport fairing on it which ties it all together and takes away the "stilts" look of the 14" T-Bars.
This bike was a chrome ***** Wide Glide when I bought it....I got it cheap as **** and fixed it.
I hate Wide Glides.
I hate Wide Glides.
Shouldn't be too bad....Tachs are easy as hell to wire up and the mechanical speedo is even easier, The idiot lights should just wire up the same as your existing ones.
If it was my project, I would lose the P.O.S. headlight plug and wire it all with a weather proof connector.
