Time for a new Stator
Old 10-01-2018, 02:01 PM
fshaw's Avatar
fshaw
fshaw is offline
Default Time for a new Stator
Have to replace the stator in my 1990FLHS. Any that would be "best quality"; Cycle Electric, OEM, ACCel, Spyke, Compu-Fire? Not interested in upgrading to 3 phase and 32 amp is plenty.
Thanks.
Frank
Old 10-01-2018, 02:14 PM
0maha's Avatar
0maha
0maha is offline
Received 4,674 Likes on 1,663 Posts
Conventional wisdom around here is that either CE or OEM are best.
That said, I've got a couple of years on my Accel (stator and VR) without complaint.
Old 10-01-2018, 03:11 PM
misfitJason's Avatar
misfitJason
misfitJason is offline
Received 1,053 Likes on 667 Posts
Cycle electric
Old 10-01-2018, 03:27 PM
rizzo's Avatar
rizzo
rizzo is offline
Received 4,691 Likes on 2,119 Posts
I've replaced 3 OEM's in 12 years, now it has a CE unit. I've never heard anyone say they've had a failure. I got tired of replacing them, the CE unit is much more well made - I'm ready to pay for the quality. Last one didn't last 4 years of mn riding.
Old 10-01-2018, 04:45 PM
daven9113's Avatar
daven9113
daven9113 is offline
As others here suggested, I just put in a CE stator (32amp) yesterday. Letting the loctite cure and will be finishing up the job today. They have a two year warranty. The brands you listed are all good companies, and I don't think you would go wrong. Just stay away from Chinese made stator, and you will be good. Last Chinese stator I had lasted 16K miles.
New stator:
Be sure to put loctite on the bolts. They come with dried loctite on them, but I don't trust it. This is what happens (two stators ago) when you trust pre-applied loctite.
Old 10-02-2018, 06:42 AM
fshaw's Avatar
fshaw
fshaw is offline
daven9113,
Did you use blue loctite on the stator bolts?
I believe CE recommends purple loctite (222) on the bolts that hold the plug retainer.
Thanks.
Frank
Old 10-02-2018, 10:31 AM
daven9113's Avatar
daven9113
Originally Posted by fshaw
daven9113,
Thanks.
Frank
I used blue loctite. And I also used loctite on the little screws that go into the engine case holding the plastic piece. The CE stator does come with brownish dried loctite on their bolts, but I don't trust how long that's been sitting on the shelf.
Old 10-02-2018, 03:19 PM
glidein wide's Avatar
glidein wide
glidein wide is offline
Had good luck with compufire so far.
Old 10-04-2018, 06:10 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 5,407 Likes on 3,616 Posts
The most important thing here is to make sure the Rotor is properly shimmed out from the Stator. I have seen where the windings on the stator have rubbed on the inside of the Rotor....
86glider
EVO
05-25-2019 08:41 AM
Hawgnuttz
Electrical/Lighting/Alarm
07-05-2018 03:20 PM
soft 02
10-18-2011 08:20 PM
Keener
09-24-2008 08:10 PM
Quick Reply: Time for a new Stator
