1985 FXRS front turn signals
Old 03-13-2017, 09:23 AM
14GuineaPig's Avatar
14GuineaPig
14GuineaPig is offline
FOR 1986 FXRS - Looks like the housing for the headlight. Looks like the tach has it's own ground.
Old 03-13-2017, 10:46 AM
CheefASRC's Avatar
CheefASRC
CheefASRC is offline
I wonder if 1985 is the same, and if so, black for ground?
Old 03-13-2017, 11:08 AM
14GuineaPig
The Headlight & Tach use a BK (Black) wire for the ground.
See if this link works for you. It can take a while to load.
https://serviceinfo.harley-davidson....D1986%2Bwiring
CheefASRC (03-13-2017)
Old 03-13-2017, 02:08 PM
CheefASRC's Avatar
CheefASRC
Negative, this is what I get; CORRUPTED PDF file.
It was my work PC, must have blocked it. Thanks!
Old 03-13-2017, 02:24 PM
CheefASRC's Avatar
CheefASRC
hmm that COULD be the problem, as I don't see any black wire coming out from the Tach to the tripe trees?
Old 03-13-2017, 04:23 PM
14GuineaPig
The Tach should have a Pink - Bottom of coil; Orange - Accessory Circuit Breaker; Black - Ground
Old 03-13-2017, 07:43 PM
CheefASRC's Avatar
CheefASRC
I believe I found it. Loose wire going into the headlight bucket. I jammed a small piece of rag into it and it's working now. I'll have the Indy fix it when I get it inspected. Thanks for all who helped!!
Old 03-13-2017, 08:21 PM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,361 Likes on 1,953 Posts
Glad you got it figured out.
Electrical problems are almost always a PITA!!!!
Old 03-13-2017, 08:36 PM
CheefASRC's Avatar
CheefASRC
No doubt Texas! If I had any hair, I would have yanked it out by now!
Rick5150
EVO
08-14-2016 08:44 AM
Solly
01-27-2013 01:50 PM
MotoTrav
Electrical/Lighting/Alarm
08-07-2012 07:50 AM
eastcoastink
06-26-2012 08:45 PM
Daehawc
06-15-2009 06:57 AM
Quick Reply: 1985 FXRS front turn signals
