Shifter Shaft Bushings?
12-13-2015 | 06:14 PM
Are there any serviceable bushings for the shifter shaft in the area marked in the picture below? My shifter has a lot of slop in the shaft housing. Thanks
12-13-2015 | 06:36 PM
WP 50 just replaced his.
He should be along.
12-13-2015 | 06:37 PM
Great~! Hope he can give me some direction!
12-13-2015 | 06:39 PM
Yep ... I've replaced them a few times 33713-85 should be the number.
12-13-2015 | 06:49 PM
12-13-2015 | 06:54 PM
Two ( 2 ) and you might want to inspect/replace the shaft while doing it. It's a simple job.
From memory two ....easy to replace and makes a world of difference.
12-13-2015 | 06:57 PM
Ok Thanks. Now...if I can only find a pair...
12-13-2015 | 07:07 PM
12-13-2015 | 07:15 PM
They are this web thing. I had a hard time trying to get them out and eventually when I had the inner primary off for something else, I beat them out. I replaced them with a sleeve I made from Delrin. It works great now.
