Trouble shooting possible oil issue
Old 09-07-2014, 08:45 PM
MNroadglideguy's Avatar
MNroadglideguy
MNroadglideguy is offline
Stage III
Default Trouble shooting possible oil issue
I have a 07 Road Glide. Long story short, Had to put some oil in it the other night and not being really to see I over filled it, and as usual all the bad things happened, oil blowing and smoking. The next morning, drained it (2 hrs to make sure it was all drained) and as per the manual put 3.5 quarts in. Every thing seemed fine until I was 5 miles from home and it started blowing and smoking again. Any ideas to what may be wrong? Breather? Oil line plugged? Thanks for any help!
Old 09-07-2014, 08:50 PM
QC's Avatar
QC
QC is offline
Received 19,804 Likes on 9,867 Posts
My guess is the residual oil in places it shouldn't have been is still burning off.
Old 09-07-2014, 10:46 PM
baloot-boy's Avatar
baloot-boy
baloot-boy is offline
3.5 quarts is too much even though the manual says thats what to fill it at. Ask me how I know. You will need to drain/suck some out. With oil change, I usually add two quarts, then add as needed until oil registers right. When cold you want oil to register in the between the fill and full marks, no more than half way to full. When hot at normal operating temp, you want the oil to register at the full mark or a little lower. Also make sure you do all this on the jiffy stand and not with the bike standing straight upright.
Old 09-08-2014, 06:01 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,868 Likes on 2,430 Posts
All holes have a LEVEL to which oil should be filled! In your case it's the dipstick. You only need 3.5 quarts to hand when refilling, don't just chuck it in!
Old 09-08-2014, 08:56 PM
MNroadglideguy
Stage III
Default Thanks
Thanks for the help everyone.
Old 04-13-2020, 05:26 PM
Stan Proffett's Avatar
Stan Proffett
Stan Proffett is offline
4th Gear
Default jif
[QUOTE=baloot-boy;13193004]3.5 quarts is too much even though the manual says thats what to fill it at. Ask me how I know. You will need to drain/suck some out. With oil change, I usually add two quarts, then add as needed until oil registers right. When cold you want oil to register in the between the fill and full marks, no more than half way to full. When hot at normal operating temp, you want the oil to register at the full mark or a little lower. Also make sure you do all this on the jiffy stand and not with the bike standing straight upright.[/QUOTE 06 SG has no jiffy stand
Ben221 (04-14-2020)
Old 04-14-2020, 06:31 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
Sounds over-full, unless the crankcase is containing excess oil, ie sumping.
Scott
Old 04-14-2020, 07:37 PM
Ed Ramberger's Avatar
Ed Ramberger
Ed Ramberger is offline
You need to run it on the jiffy stand for a minimum of a minute prior to draining the oil. If you had it really overfull, there was most likely excess oil in the breather system and/or you didn't run it on the jiffty stand and evacuate the crank case.
3.5 quarts is not too much on a dry fill on a bagger. Scott makes a good point, but if everything was fine until the overfill, I wouldn't freak out just yet.
Ben221 (04-14-2020)
Old 04-15-2020, 04:35 AM
grbrown's Avatar
grbrown
grbrown is offline
Cool
6 year old post chaps! C-19 has struck again I suspect. I will simply repeat my mantra that all the oil reservoirs on our bikes have a dip-stick or other guide for checking level, the stated quantities are only for guidance, not to be used blindly.
Old 04-15-2020, 06:31 PM
Ed Ramberger
Well damn, lol
grbrown (04-16-2020)
Quick Reply: Trouble shooting possible oil issue
