Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I was changing the nose cone on my 89 fxr & the cam got pulled out my Q is the timing mark in the hole on left side have to be lined up to set the 2 marks on the cam gear on right side
they don't seem to line up on both sides ????
thx noel
