Cam plate and hi-flow oil pump
If i remember correctly your bike has very low miles. Save the money. Without that extra chit that the dealer probably recommended your bike isnt going to blow up like a grenade. Opinions are like ********, everyone has one. Report back on the improvements you get from the 255. It should be a kick in the ***.
Scott and Kirby, would you recommend the SE billet plate PN 25284-11 on a 2004 FI 95/ 98" build to upgrade to hydro tensioners or use a 07 up stock plate? I'm doing a lot of research for a build once i get back to the states and planned to use the billet plate. any advise or suggestions would be appreciated.
I would look into thayers sales and services new upgraded cam plate and oil pump setup. Dan told me R&R cycles and TMAN uses it on all there build setups it returns the oil back into the base instead of filling up the cam chest. saw his C&C machine producing them when I was getting my bike tuned at his shop. very nice setup.
I'm thinking about installing the Tman 555 Torqster cam in mine. The 255 I currently have installed but it runs really hot. The 555 torqster from what I have been told holds the valves open longer to help get some of the hot gasses out of the motor, and supposedly has even a better performance. I'm not into speed but love that seat of the pants pull.
