Engine cutoff when high temperatures could cause engine damage
Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I want to know if my 2008 road king flhr has that rear cylinder shutoff when engine gets to hot. I tried turning the throttle backward twice but I did not get any change in engine idling. Anybody help is appreciated.
