Are all oil pumps created equal
Old 06-17-2014 | 05:31 PM
ead78's Avatar
ead78
6th Gear
Default Are all oil pumps created equal
Need a little help on this one. 99 wide glide with 88 tc. Changing out cam chain tensioners and was inspecting oil pump for any wear. Removed parts in order of first, thin feed gear, thick(maybe 1/8 inch) washer, and thick return gear. With these installed in pump everything was flush with the pump housing. The manual shows two washers and a wave washer. No way that would fit and still be flush with pump housing. Don't know. Maybe PO upgraded pump gears or something is missing. Always had good oil pressure. Any ideas on this would be appreciated. Thanks
Old 06-18-2014 | 06:45 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Those very early pumps were like that, from what we've seen.
Your good.
Scott
Old 06-18-2014 | 08:52 AM
ead78's Avatar
ead78
6th Gear
Thanks Scott
Dazzauk
EVO
134
07-05-2018 08:32 PM
madskilz102
Shovelhead
07-06-2014 10:19 PM
imboden
Shovelhead
10-07-2013 06:04 PM
panfisher2
Ironhead
07-15-2011 05:53 AM
panfisher2
Exhaust System Topics
07-12-2011 03:31 PM
